TwinTurbo.NET: Nissan 300ZX forum - Re: Re: I don't see why an O2 sensor (NB or WB) being downstream
Subject Re: Re: I don't see why an O2 sensor (NB or WB) being downstream
Posted by Dallas DamonZ on December 06, 2007 at 5:06 PM
  This message has been viewed 185 times.
In Reply To Re: I don't see why an O2 sensor (NB or WB) being downstream posted by Dallas DamonZ on December 06, 2007 at 05:02 PM
Message if you're not tracking RPM or some other trigger, then all you're doing is looking for a rich/lean mixture (min/max) while in a certain condition (IE WFO), timing really won't matter. If you datalong in order to actually tune the engine across the RPM band, then you need to know what this delay time amounts to so you correct the right values in the maps.
Later
Click here to e-mail me!Click here for Twin Turbo Zs of Dallas!
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
When was the last time you *really* did something with your Z to call yourself a Z enthusiast?
Member #1 PETZ
