TwinTurbo.NET: Nissan 300ZX forum - You need to maintain engine vacuum for PCV. Your
Subject You need to maintain engine vacuum for PCV. Your
Posted by AzHeat on February 19, 2007 at 2:33 PM
  This message has been viewed 1045 times.
In Reply To Question for you >>> posted by SlicktopTT on February 19, 2007 at 12:03 PM
Message set up can be harmful to the engine under high boost because you have no engine vacuum to de pressurize the crankcase. Woody's reroute deals with the PCV system that works when the engine is not in boost mode. In boost mode the PCV valves will shut cause they are one way valves. If they didn't shut boost pressure would go into the valve covers. The hose pipes on the front of the intake valve covers are always under vacuum because they are in front of the turbos .
