TwinTurbo.NET: Nissan 300ZX forum - Yeah that thing is a bitch ain't it?
Subject Yeah that thing is a bitch ain't it?
Posted by Broke_as_**** on February 04, 2007 at 11:52 PM
  This message has been viewed 238 times.
In Reply To removing bushing from crankshaft posted by gt300zxtt on February 04, 2007 at 11:40 PM
Message Fortunately it's made from some pretty soft metal. Measure the depth of the spacer and mark that off on a drill bit using some tape. Then proceed to bore a hole in the spacer until you're down to the tape on the bit. Use a big set of pipe pliers or something on the part of the spacer that sticks out and crush that bitch. Should come right out after that.
All you have to do is be careful not drill at an angle and hit the crank and you'll be fine. If you still can't get it out, drill more holes. Hope it helps.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
