TwinTurbo.NET: Nissan 300ZX forum - Remove the SAFC first. (n/m)
canyoncarver
on January 22, 2007 at 8:31 AM
I'll have to check the belt then. Are you familiar
posted by Worm Boy
on January 21, 2007 at 07:15 PM
What does cold weather have to do with my
Worm Boy
19:26:17 01/19/07
How bout Fuel Pressure Regulator or Fuel Damper? (n/m)
TTFairladyZ
19:32:57 01/19/07
I forgot to add that to the list. Did all fuel related
Worm Boy
19:34:50 01/19/07
hard starting when cold
wilkendw
20:42:05 01/19/07
Timing is on 15 btdc, plugs are gapped correctly,
Worm Boy
21:00:38 01/19/07
The O2 sensors only affect the car while it's
Worm Boy
22:08:43 01/19/07
Re: The O2 sensors only affect the car while it's
wilkendw
09:52:58 01/20/07
What AFR issues could be associated? I'm thinking
Worm Boy
16:51:41 01/20/07
Re: What AFR issues could be associated? I'm thinking
wilkendw
01:06:17 01/21/07
I ended up putting starting fluid in the intake and it
Worm Boy
15:35:15 01/21/07
I tried turning my car on this morning around 4a.m. before
Worm Boy
15:46:06 01/21/07
Did you check ignitor module ? (n/m)
njz
21:45:55 01/19/07
You mean PTU? IF so, I did replace it along with
Worm Boy
21:53:35 01/19/07
How cold are you talking?
SactoTodd
10:14:01 01/20/07
Oh not that cold. The coldest it gets over here in
Worm Boy
16:34:57 01/20/07
Did you have it load tested? (n/m)
SactoTodd
17:51:09 01/20/07
Yes, I took it to AutoZone. (n/m)
Worm Boy
18:26:59 01/20/07
Re: Yes, I took it to AutoZone.
merlin3
18:29:13 01/21/07
Re: What does cold weather have to do with my
canyoncarver
18:35:53 01/21/07
Worm Boy
19:15:13 01/21/07
Remove the SAFC first. (n/m) -
canyoncarver
08:31:54 01/22/07
