TwinTurbo.NET: Nissan 300ZX forum - hard starting when cold
Subject hard starting when cold
Posted by wilkendw on January 19, 2007 at 8:42 PM
  This message has been viewed 133 times.
In Reply To What does cold weather have to do with my posted by Worm Boy on January 19, 2007 at 07:26 PM
Message once you get it started check the timing make sure it is 15 btdc. Incorrect timing can cause hard starts. Check plug gap. Next do a boost leak test - leaks will affect AFR and cause hard starting. Check your fuel pressure. Do the O2 diagnostic. Check your TPS function. Clean TB's. Use an inductive timing light and confirm you are getting spark when cranking. If you have fuel and spark, correct timing and AFR are the key.
