TwinTurbo.NET: Nissan 300ZX forum - Solder Flux is your friend (n/m)
TheSlimOne
on December 22, 2006 at 11:01 PM
Lol... yes i will admit, soldering is deffinitely not one of
posted by NobleZ
on December 21, 2006 at 03:16 PM
The simplest mod so far... switched power injector rewire.
NobleZ
10:54:33 12/21/06
VTF! (n/m)
CaliguyPurdue
11:03:33 12/21/06
Nice. Looks like # 1 should be "disconnect battery". :) (n/m)
Dustin
11:39:13 12/21/06
Damn, and I thought I put in every step....
NobleZ
13:04:17 12/21/06
Good, VTF! (n/m)
Slobo7x
11:39:53 12/21/06
While I doubt there are significant disadvantages in doing
Zirvana
12:24:37 12/21/06
its more for keeping the newer 555cc nismo's that cost $900
NobleZ
13:22:45 12/21/06
Don't you think the Nissan electronic engineers would have
Zirvana
14:14:22 12/21/06
If I understand correctly, Nissan DID do it on later harness (n/m)
Crim
15:13:00 12/21/06
Probably because of safety concerns. To kill the power to
Zirvana
16:13:22 12/21/06
Re: Don't you think the Nissan electronic engineers would have
Pacmanpth
15:33:41 12/21/06
Having a bad day? Jeesh. He's not even responding to you. (n/m)
doug8867
16:11:49 12/21/06
I happen to be very experienced in electronic design. Been
Zirvana
16:15:57 12/21/06
you feeling alright there buddy? (n/m)
ZEngineer
12:23:55 12/22/06
Note: this mod is for the pre-95 wiring harness.
SlicktopTT
15:57:50 12/21/06
Do you think the fuel is in contact with the injector's coil
Zirvana
16:17:17 12/21/06
It is. Thats why I throw this theory in the trash can.
spddracer
17:27:46 12/21/06
Any thoughts on why the did fail? (n/m)
lazer(AK)
13:42:53 12/22/06
*reminder: disconnect battery first
NobleZ
13:07:01 12/21/06
Too bad we'll never know if this actually has any affect (n/m)
spicyZ
13:27:26 12/21/06
Classic 'cold solder joint'...
Chas
13:33:15 12/21/06
Can't do better than speculation, but it doesn't hurt
JBender
13:58:45 12/21/06
NobleZ
15:16:53 12/21/06
Solder Flux is your friend (n/m) -
TheSlimOne
23:01:05 12/22/06
so...step 6
spyhunterTT(nj)
13:59:03 12/21/06
That gives the ecu its constant power...
NobleZ
15:19:52 12/21/06
I thought that was confusing as well
300zx90 (CO)
12:02:52 12/22/06
what is the point of injector rewire????????? (n/m)
redfarsi
15:46:10 12/21/06
With the pre-1995 design, + 12 VDC goes to one side of
Zirvana
16:37:05 12/21/06
FYI, I have 4 original 90 injectors that have lasted 138k.
doug8867
16:07:37 12/21/06
Good job on figuring out this mystery! FYI - A better way
jzack
16:34:19 12/21/06
yeah actually I thought about doing that but, I thought
NobleZ
18:04:20 12/21/06
For others -- my tip should have said using SOLID 20 or
jzack
21:25:39 12/21/06
A Note on pin 58 in certain EFI Harnesses
mjm0771
07:46:34 05/23/08
Re: A Note on pin 58 in certain EFI Harnesses
RomChip200
06:10:47 05/28/08
