TwinTurbo.NET: Nissan 300ZX forum - Classic 'cold solder joint'...
Subject Classic 'cold solder joint'...
Posted by Chas on December 21, 2006 at 1:33 PM
  This message has been viewed 1251 times.
In Reply To The simplest mod so far... switched power injector rewire. posted by NobleZ on December 21, 2006 at 10:54 AM
Message No one should use that as an example of soldering. Would be better off with a crimp connector joint than that. When your car quits running because the injectors don't work, remember to check that splice.
Also, does anyone have any hard evidence that this is going to prevent injector failure. Mine failed this summer the week the ethanol hit stations, but I am not convinced this is going to help.
