TwinTurbo.NET: Nissan 300ZX forum - Re: Engine builders Can I get away with retouqeing heads
Subject Re: Engine builders Can I get away with retouqeing heads
Posted by Tech@EPR on May 24, 2012 at 12:19 AM
  This message has been viewed 199 times.
In Reply To Engine builders Can I get away with retouqeing heads posted by 93 Blue Z32(NC) on May 23, 2012 at 10:38 PM
Message pull cometics and install OEM (copper coat them) and then your problems will most likely be solved.
Cometics are becoming increasingly prone to leaking boost pressure/compression etc into the coolant system. The only MLS gasket I would ever suggest running is a Tomei. While they are more expensive than Cometics their features are by far the best on the market for an MLS setup. If you can't spring for Tomei gaskets I'd advise my first statement above.
Ep Racing | Create Your Badge
