TwinTurbo.NET: Nissan 300ZX forum - Engine builders Can I get away with retouqeing heads
Subject Engine builders Can I get away with retouqeing heads
Posted by 93 Blue Z32(NC) on May 23, 2012 at 10:38 PM
  This message has been viewed 173 times.
Message has 87.5mm pistons Cosmetic metal head gaskets
I keep blowing the water out over flow tank when runing 15 psi of boost
If I don't boost the z will never over heat and wont lose water(drove back from ZDayz)
There are no external leaks
Hooked up radiator pressure tester gauge reads zero rev the engine 3 times and gauge reads 23 psi
