TwinTurbo.NET: Nissan 300ZX forum - 98 spec transmission break in
Subject 98 spec transmission break in
Posted by aliaZ on May 04, 2012 at 7:27 AM
  This message has been viewed 818 times.
Message I talked with Mike Smith yesterday about a noise problem a customer has with his 98 spec transmission. I have the same issue with mine.
I found out that the break in oil that ships with the transmission should only be used for a few hundred miles under light load, and then changed out for a quality synthetic. The break-in oil can't handle high loads, and will cause the input shaft gear and counter gear teeth to become polished, which causes a whirring noise most noticeable while idling in neutral.
Wish I would have known this before...sigh
I'm wondering if redline shockproof would help with this?
