TwinTurbo.NET: Nissan 300ZX forum - clean maf sensor with electrical cleaner and clean sensor
gt300zxtt
on May 06, 2008 at 3:52 PM
Jercking and Idle problem...
posted by SPOOLN2
on May 06, 2008 at 03:39 PM
plug connector from any corrosion. if you have a pop charger, are you using a baffle to keep wind and turbulence from affecting maf readings? also, clean your air filter if you have a reusable one, while you are at it.
SPOOLN2
15:39:34 05/06/08
clean maf sensor with electrical cleaner and clean sensor -
gt300zxtt
15:52:31 05/06/08
CRC sells a MAS cleaner. Pep Boys has it. Although
ThunderZ
17:04:05 05/06/08
Is the car jerking while deaccelerating in gear?
TTFairladyZ
18:29:55 05/06/08
Clean electrical connections, check your fuel and air
300ZMang
22:25:13 05/06/08
Thanks guys! I'll try all that out (n/m)
SPOOLN2
22:54:31 05/06/08
