TwinTurbo.NET: Nissan 300ZX forum - That has a specific heat of 2.67 j/g C. No better than...
Kenny 9 psi
on August 20, 2003 at 8:54 AM
What about.....
posted by Christopher
on August 19, 2003 at 11:45 PM
...antifreeze.
Cupholder?
Kenny...
PETZ Member #5
Engine cooling theory... (very boring, Cliffs notes at top)
Kenny 9 psi
21:27:19 08/19/03
There are two reasons antifreeze, freezing & lubrication
Turbodog (CT)
21:49:21 08/19/03
As mentioned below, antifreeze also increases boiling point.
Kenny 9 psi
23:36:22 08/19/03
Does antifreeze raise the boiling temperature of water also?
CaptK(ATL)
22:08:46 08/19/03
raises bp/lowers ability to transfer heat. Tdog is spot on
FLYT300
22:28:59 08/19/03
Pressure raises the boiling temp of water though... (n/m)
quikz
23:13:51 08/19/03
I know... (n/m)
CaptK(ATL)
10:08:06 08/20/03
Damn...I can't find my Thermodynamics book
Tredmil
22:28:22 08/19/03
simple solution: water + redline water wetter (n/m)
crazydonkey
22:50:08 08/19/03
Good post =). (n/m)
Kenny 9 psi
23:38:53 08/19/03
Glad to help.
Tredmil
01:23:10 08/20/03
Reactors use heavy water though--Deuterium or Tritium
therinL
10:13:20 08/20/03
...and that's something you don't want in your car.
Kenny 9 psi
09:08:40 08/21/03
What about.....
Christopher
23:45:31 08/19/03
That has a specific heat of 2.67 j/g C. No better than... -
Kenny 9 psi
08:54:57 08/20/03
Ok I.....
Christopher
17:41:38 08/20/03
Re: Ok I.....
Kenny 9 psi
09:19:28 08/21/03
All our racers use water with corrosion inhibitor.
zads
07:40:35 08/20/03
i would argue there's something better than water >>>
Bernie (OOParts International)
10:38:27 08/20/03
In addition to the heat capacity, you need to consider>>>
PEwithaZ
13:23:52 08/20/03
Good info =). (n/m)
Kenny 9 psi
16:51:24 08/20/03
I LOVE seeing posts like this - a model for all to follow
blaZe
13:29:27 08/20/03
w00t! (n/m)
Kenny 9 psi
16:49:01 08/20/03
Ever consider heavier isotopes of H? HEavy Water? (n/m)
Borg79(ON)
16:57:21 08/20/03
Nope. Same specific heat, but much more expensive...
Kenny 9 psi
09:07:10 08/21/03
