TwinTurbo.NET: Nissan 300ZX forum - 'valve float' is first most common problem.
Subject 'valve float' is first most common problem.
Posted by nixit on July 15, 2003 at 1:27 PM
  This message has been viewed 56 times.
In Reply To How is the redline limit determined? posted by shirow on July 15, 2003 at 12:40 PM
Message if the cam is rotating too fast, the valve will not reseat properly, allowing compressed air to leak.
generally, they change cam profile and valve spring rates to compensate for valve float.
but when you increase RPMs, you have to have a custom grind to get enough air into the cylinders to prevent going lean.
it's not a simple a=b.
it effects everything else in the line of duty tho, so it's not just a single 'mod'
