TwinTurbo.NET: Nissan 300ZX forum - Weird things are going on after belt kit, spark plug change
Subject Weird things are going on after belt kit, spark plug change
Posted by Sam(Houston) on June 03, 2003 at 10:22 PM
  This message has been viewed 96 times.
Message I got Ngk spark plugs, and a total timing belt kit from Coz(awsome dealer), which includes:
Timing belt
Timing belt tensioner
water pump
water pump gasket
thermostat
coolant bypass hoses
variable timing control springs
variable timing control o-rings
camshaft seals
crankshaft seal
crankshaft sprocket spacer
drive belts(3 included)
Well after all this in, now my car is doing some werid things, for example;
When turned on it would idle high when the car is already warmed up. But it goes down after 2-3 minuts.
When you gun it and let go it would act like its going to die but it wont.
My battery volt was on like 14.0 or 14.1 now its like 13.6 or 13.7.
My fan turns on alot more now, Like the car is over heating but its not. I did not drive it hard at all..
Any help would be awsome.
Thx.
I plan on sitting in my front yard with a sign that says 'Fuck off' & wait for Nixit to return to Dallas because I need a brake bleeder. See what Bin Laden has to say to that? Posted by: Dallas DamonZ on February 12, 2003 at 12:48 AM
