TwinTurbo.NET: Nissan 300ZX forum - Re: Should I worry? How serious is the high temp problem (more)
Subject Re: Should I worry? How serious is the high temp problem (more)
Posted by MyWhiteZTT(NJ) on May 30, 2003 at 2:14 PM
  This message has been viewed 52 times.
In Reply To Should I worry? How serious is the high temp problem (more) posted by kcmichaelm on May 30, 2003 at 12:34 PM
Message Stock turbos are T25's. Most T28's are just stock housings bored out with a bigger wheel. The problem with the T28's is that when you try to cram more air through the same small housing it creates heat. So, you end up just blowing a bunch of hot air into the engine and not really getting a whole lot more power. It's all about efficiency with turbos.
later,
eric
