As far as I can find max voltage the MAF is capable of is 5.12v but apparently its inaccurate at that level so 5v is max. Are you running dual MAF? If not its possible you're maxing the MAF. In reviewing the ConZult logs do you peak at 4.9v prior to letting off? That would possibility be an indicator.
