TwinTurbo.NET: Nissan 300ZX forum - Oil pressure isn't what makes bearings last though Chip>>
Subject Oil pressure isn't what makes bearings last though Chip>>
Posted by AshsZ (FabZEM All) on May 23, 2003 at 10:13 PM
  This message has been viewed 151 times.
In Reply To Get rid of the oil squirters will increase oil pressure posted by Chip(GinnMotorsports) on May 23, 2003 at 09:44 PM
Message Typoically you want 10psi of oil pressure for every 1000RPM. This ensures that there is significant oil making its way to the journal - not that there is 10psi more support in the bearing for every 1000RPM. The oil itself is the bearing - you just need to make sure you have enough oil getting there. The rod bearings are just a weak point and I would say that eliminating the piston cooling ability is going to offer only a disadvantage. There's plenty of oil getting to the entire engine, its just that the rod bearings are a little too small.
[ ashleypowers.com ]
[ agpowers@bellsouth.net ]
[ Zemulator Information Sheet ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
