TwinTurbo.NET: Nissan 300ZX forum - Why not do a MAP sensor...much better for high Hp... (n/m)
Kyle(Houston)
on February 25, 2003 at 1:39 PM
I will have a dual-intake setup which will not require
posted by AshsZ (FABio)
on February 25, 2003 at 01:25 PM
I Have Heard Some Bad Rumors about Lightened crank pulleys..
5liter-eater
11:16:38 02/25/03
Absolutely, 100% YES, they are the worst thing EVER!!! (n/m)
my91z
11:19:41 02/25/03
Every last person who has used one has hda their engine blow (n/m)
my91z
11:20:14 02/25/03
They are SO bad oil will shoot out of your engine the >
my91z
11:20:38 02/25/03
thats enough girly man (n/m)
TARGETZ
12:34:23 02/25/03
Uh-huh.... a bit late on that comeback, eh? (n/m)
my91z
12:37:23 02/25/03
My 91 Z
seoulski
10:45:13 02/26/03
I was going to lay into you, but I'll take the high road>
my91z
16:11:49 02/26/03
Please use SEARCH for "underdrive pully" (n/m)
YugoBernie (NoVA)
11:22:29 02/25/03
yes/no (n/m)
genic
11:25:53 02/25/03
maybe (n/m)
Spee
13:03:58 02/25/03
so? (n/m)
-Ever-
13:13:14 02/25/03
I have over 20,000 miles and no problems. :) (n/m)
Spongerider (Now PFC)
11:27:55 02/25/03
There is a huge debate on this >>>
Mal1ce
11:28:32 02/25/03
Do Not Get one, IMO
WhiteOutZ
11:40:37 02/25/03
according to ASHs logic, Detonation is OK. Ask AK[zip] (n/m)
niXit
11:43:26 02/25/03
Where did you get that from?
AshsZ (FABio)
11:50:48 02/25/03
umm...haters? I don't think so
aliaZ
12:03:23 02/25/03
I wasn't pointing fingers. (n/m)
AshsZ (FABio)
12:52:20 02/25/03
Ok (n/m)
aliaZ
12:54:09 02/25/03
Aren't you going to soak people for the same price?
Turbodog (CT)
12:37:51 02/25/03
Nope. My ECU upgrade that is the same kind of upgrade as JWT
AshsZ (FABio)
12:46:07 02/25/03
what about dual MAFS?
aliaZ
12:57:28 02/25/03
AshsZ (FABio)
13:25:41 02/25/03
I'm more interested in the benefit of running...
aliaZ
13:39:16 02/25/03
Dual-intake splits the air between two filters so you
AshsZ (FABio)
13:42:00 02/25/03
ok I misunderstood (n/m)
aliaZ
14:35:17 02/25/03
Why not do a MAP sensor...much better for high Hp... (n/m) -
Kyle(Houston)
13:39:32 02/25/03
The ECU uses a VE calculation to determine engine load
AshsZ (FABio)
13:44:33 02/25/03
Everything I have read, has said MAP is very innaccurate.
niXit
14:13:23 02/25/03
Hmmm
Marshall
14:24:14 02/25/03
Any race car I have ever seen has had a Map sensor--->
Kyle(Houston)
07:40:48 02/26/03
Yeah, having one for 85K w/ 205K on motor is WAY unreliable. (n/m)
my91z
11:49:27 02/25/03
You also have an NA. (n/m)
AshsZ (FABio)
11:52:03 02/25/03
Which sees redline everyday it is driven...your point is? (n/m)
my91z
11:53:53 02/25/03
Its not specific to RPM - its specific to torque.
AshsZ (FABio)
11:57:25 02/25/03
I agree with this (n/m)
aliaZ
12:04:39 02/25/03
I don't buy it. I think it's an NVH issue >>
my91z
12:18:37 02/25/03
Ok. (n/m)
AshsZ (FABio)
12:21:29 02/25/03
So this is Ash's opinion, not yours then? (n/m)
Woody75 (Denver)
11:56:12 02/25/03
Oh boy.. Thanks for the support, but you're gonna get it..
AshsZ (FABio)
11:58:24 02/25/03
nice blanket statement :-/ (n/m)
aliaZ
12:05:35 02/25/03
Yup. (n/m)
AshsZ (FABio)
12:22:02 02/25/03
I see your pattern, "yup, ok", I like that new you =) (n/m)
ZEngineer
12:27:26 02/25/03
Hmmmm... My engine has a little shimmy between 2200-3500>>>
Bobby12many
12:05:06 02/25/03
I know what you're talking about...
ZEngineer
12:07:50 02/25/03
Damn does it bother me... (n/m)
Bobby12many
12:14:19 02/25/03
Mine does too
Marshall
12:21:50 02/25/03
yes, but mine's a separate issue
ZEngineer
12:30:30 02/25/03
I know what you are talking about>>>
Bobby12many
12:36:33 02/25/03
yes, make it stop Bobby, MAKE IT STOP!! =( (n/m)
ZEngineer
12:42:37 02/25/03
Oh, I will. :) New DS, Diff Bushings, Trans Isol Mount go on
Bobby12many
13:51:50 02/25/03
I have a great diff bushing writeup here if you need it (n/m)
ZEngineer
14:05:09 02/25/03
If youre referring to the one Mike(my91z) wrote, I got it :)
Bobby12many
14:16:38 02/25/03
yup, that's the 1. You're all set I guess, good luck (n/m)
ZEngineer
14:25:50 02/25/03
Sounds exactly like my car... Exactly (n/m)
Bobby12many
12:32:43 02/25/03
Check your U-joints, my Jeep does that when they R going out
my91z
12:50:57 02/25/03
that is possible.
Marshall
13:29:39 02/25/03
dont be surprised if as you're checking it,
ZEngineer
14:10:01 02/25/03
You're probably right.
Marshall
14:26:07 02/25/03
You forgot the key words, was it a tested on a VG or
12:17:38 02/25/03
Shorter crank only means the resonant frequency is higher
AshsZ (FABio)
12:33:21 02/25/03
Nope...
12:48:15 02/25/03
Ok. (n/m)
AshsZ (FABio)
12:50:43 02/25/03
that's overly simplied
Marshall
13:10:15 02/25/03
It is possible to move the resonant frequency out of range?
Marshall
12:55:07 02/25/03
In a good design, yes but >
kuah@splparts.com
13:05:30 02/25/03
Nope. Harmonics allow lower frequencies to amplify higher
AshsZ (FABio)
13:06:13 02/25/03
Re: Shorter crank only means the resonant frequency is higher
SactoTodd
12:55:35 02/25/03
An ant can carry many more times its own weight. (n/m)
AshsZ (FABio)
13:39:40 02/25/03
I got this information from Jim at Sunbelt in GA >>>
Mal1ce
17:52:00 02/25/03
no problems here. (n/m)
wickdGSXR
11:47:22 02/25/03
I think its dependent on the HP the car is producing.
AshsZ (FABio)
11:55:25 02/25/03
Agreed, NAs will last long, but a high HP TT will not enjoy
George(boostsolutionsinc.net)
12:03:14 02/25/03
Yep.
Dallas DamonZ
12:15:33 02/25/03
I ran an underdrive pulley from late 97-late 00 and *NEVER*>
Kyle(Houston)
12:21:50 02/25/03
*shrug*
AshsZ (FABio)
12:24:21 02/25/03
LOL.....True..I just have never seen any *actual* proof--->
Kyle(Houston)
12:30:21 02/25/03
I will agree with that. A friend here had an odd plug
AshsZ (FABio)
12:41:01 02/25/03
And what do you suppose a lightweight flywheel does to the >
my91z
12:44:53 02/25/03
harmonic dampers are filled with rubber
Marshall
13:03:19 02/25/03
?? I don't see your point? The "damper" is still tuned>
my91z
13:14:31 02/25/03
I'll reply with Kuah's answer- it doesn't need to be tuned.
Marshall
13:24:38 02/25/03
Just like shocks on a car don't need to be tuned 2 the mass?
my91z
13:28:37 02/25/03
The shocks on a car should just dampen anything
Marshall
13:36:44 02/25/03
Actually, the damper compression and rebound, but >>
my91z
13:51:00 02/25/03
it's possible...
Marshall
14:13:46 02/25/03
flywheels do nothing to dampen harmonic vibrations
aliaZ
13:08:40 02/25/03
And I said any of this where? >>
my91z
13:17:39 02/25/03
It would actually lower the tortional flexion because
AshsZ (FABio)
13:09:19 02/25/03
Did anyone actually read my post?
my91z
13:31:18 02/25/03
Yup. I answered. (n/m)
AshsZ (FABio)
13:38:30 02/25/03
I did.
Marshall
13:46:21 02/25/03
That is how it operates. It dissipates the vibration
AshsZ (FABio)
13:55:34 02/25/03
You need to look at it in the relative oreders of magnitude>
my91z
14:01:36 02/25/03
Yes I understand that.
Marshall
14:19:55 02/25/03
Such dampeners do not need to be "tuned" for a frequency
kuah@splparts.com
13:10:22 02/25/03
You are re-iterating what I said. I said that by changing >
my91z
13:27:28 02/25/03
Re: You are re-iterating what I said. I said that by changing >
kuah@splparts.com
13:45:50 02/25/03
I agree about the fixed end point, I hadn't thought >
my91z
13:57:29 02/25/03
I guess I was overzealous, it would reduce the effcetivness>
my91z
13:33:52 02/25/03
I have the ASP UDP on my NA,
shawn300zTT
12:23:44 02/25/03
I have installed well over 150 UR Pullies......
Specialty-Z
13:11:50 02/25/03
Greg do you have the picture of the whole stack of about 40
YugoBernie (NoVA)
13:59:02 02/25/03
I have it somewhere at home...it's great! (n/m)
SeedyROM
14:18:29 02/25/03
Find that sh!t for me please. (n/m)
YugoBernie (NoVA)
14:55:27 02/25/03
