TwinTurbo.NET: Nissan 300ZX forum - Removing EGR & AIV causes what potential problems?
Milo (San Antonio, TX.)
on February 25, 2003 at 9:36 AM
I realize I would get a slightly higher cylinder temp but what else to look for? Running rich or lean or what else?
Removing EGR & AIV causes what potential problems? -
09:36:35 02/25/03
running lean and excess crack case pressure..
Halo Z
10:05:17 02/25/03
I thought pcv is what relieves pressure from crankcase?????? (n/m)
ScubaSteve
10:11:25 02/25/03
yes, you are correct. im sorry. (n/m)
Halo Z
11:44:16 02/25/03
you run lean from removing the EGR?
KaZ (jTTfz) VaBch
10:18:05 02/25/03
i have a lot of reasons im running lean... (n/m)
Halo Z
10:25:14 02/25/03
both AIV and EGR shouldn't effect on A/F ratio..
JZ
11:35:22 02/25/03
damn I hate excessive crack pressure :-) (n/m)
aliaZ
11:19:41 02/25/03
it tends to blow dip sticks, and cam/crank seals out and (n/m)
Halo Z
11:35:53 02/25/03
rear main is the main seal effected... thats why so many are
3 double-0 ZX(Va Bch)
17:24:06 02/25/03
sorry not excess crack case pressure, i was thinking PCV
Halo Z
11:43:41 02/25/03
The AIV should have not have any effect on the a/f ratio
11:04:07 02/25/03
Cool, A/F was a concern but that answers it. I am not
11:06:10 02/25/03
