TwinTurbo.NET: Nissan 300ZX forum - Build it with a VG33 Block and put a set of full worked DOHC
Subject Build it with a VG33 Block and put a set of full worked DOHC
Posted by Fly'n Z on February 12, 2003 at 11:23 AM
  This message has been viewed 419 times.
In Reply To NEW (StrictlyZ) Project Car Build UP? posted by Kyle (StrictlyZ.com) on February 12, 2003 at 01:51 AM
Message heads on top with all of the usual motor goodies.
You would need customer motor mounts most likely to get the VG33 block to sit in their and because it's a little taller you're also going to need a dry sump oil system to set the motor lower in the chassis. (Build for about 700 streetable hp)
Work with someone like Chip to build you a totally custom set of turbos that will attach to a set of Pentroof manifolds and spool like crazy.
Move redline to 8 grand for that top end rush.
Completly strip the car and have the chassis stitch welded for additional strength. Also foam fill hollow chassis members and weld in a roll cage.
Run a full suspension setup from Ground Control using their Advanced Design coilovers.
Finally .... find some way for the Z to loose 500 + pounds!
Wow .... this pie in the sky dreaming stuff is kinda fun, thanks for the post Kyle.
