TwinTurbo.NET: Nissan 300ZX forum - Let's get the brake data correct - please
Subject Let's get the brake data correct - please
Posted by Avalon Ent - Racing Division on November 17, 2000 at 6:50 AM
  This message has been viewed 75 times.
In Reply To <===Dusty @ MVP is already giving best deals in for sale posted by Altered BeaZTT on November 16, 2000 at 11:38 PM
Message Per Brembo Italy: ( who we work with on a regular basis)
In the USA Brembo Italy does not have any drilled rotor programs for the Z. Motor Quality "a Brembo distributor" in the USA - Slots and drills the blanks.
Companies like Stillen and KVR use Brembo cores and CNC, and Drillss as well as cadium plate themselves.
Our current specials listed below will give you a better idea of specs and prices. In addition, We have been having an ongoing sepcial for Stillen rotors front and rear for less then the above mentioned "Group Buy" post.
PowerStop's parent company Auto Authority is the manufacturuer of their brakes and uses cores from all over.
Thi sin no way shape or form indicated that any other group buys are not Brembo Rotors, BUT they are not drilled by Brembo. This comes from the Brake Development Manager @ Brembo.
SO Please be informed before you buy regardless of who you get them from.
As for Big Brake Kits,
Brembo does have the drilled/slotted for the Z. See our special this month as we have a special manufactuing run being done.
Current Specials
The first is a Brembo Big Brake kit: We have been working with Brembo in Italy and have the following kit as a group buy:
Brembo 4 Piston Caliper ¥ Light weight cast aluminum -Fixed mount for minimal caliper flex -Differential Piston sizes (2x38/44mm) minimizes pad taper and maximizes
even friction pressure -Anti Rattle springs reduce pad noise -Inner wiper and outer dust seals for everyday use Brembo 332x32mm Rotors -Directionally Curve Vein Vented for maximum cooling -Cross Drilled and
Slotted for aggressive pad bite and proper out-gassing -2 piece modular disc Brake Pad -Pad Area 64cm squared x 2 per caliper -Pad material designed for high performance road and track use -Consistent friction
co-efficient at low and high temperatures
The cost is $1919.00 + shipping for 1-5 kits and 6 kits plus is $1865.00. All firm ordfers must be received by 11/30/00.
Brembo is doing an across the board price increase at theend of the year of approx 24%. The time to buy is now.
FOR DECEMBER (non Group Buys)
Our other usual specials also are running.
$635.00 (includes shipping) for Stillen Sport Rotors (f&R), Metal Matrix Pads (F&R), Goodridge lines and fluid.
For $575.00 + $20.00 shipping in the US, we can offer the above but with PowerSlot Rotors.
Front Stillen Cross Drilled Rotors - $199.00 plus shipping
Rear Stillen Cross Drilled Rotors - $235.00 plus shipping
Regards
: Dusty is the only one authorized to buy from Brembo in the US for Jap cars. Those are true Brembos. Not Brembo blanks drilled by someone else. He's dealing all the parts of the big brake kit for a sweet group buy price. He has to get a group to get a cheap rate shipping and large order from them. Anyone else dealing them has to deal through him. He told me all this and no dealer including Brembo themselves are saying he's not for real.
2000 ZCCA Gold Medallion Recipient for Concourse Excellence
Member - Professional Detailers Assoc and the ICA
