TwinTurbo.NET: Nissan 300ZX forum - Replace tranny fluid, adjust clutch pedal, bleed the system.
Subject Replace tranny fluid, adjust clutch pedal, bleed the system.
Posted by YugoBernie (NoVA) on January 31, 2003 at 8:39 PM
  This message has been viewed 114 times.
In Reply To Clunky and hard to shift from gear to gear posted by orinoco (NC) on January 31, 2003 at 08:34 PM
Message Also inspect the transmission mount (should have replaced it when you did the clutch), the drive shaft u joints and the differential bushings.
Also don't force through the gears let the engine rpms match up as you go the syncors are wearing and you want to preserve them as long as possible.
YugoBernie Logo
"Like most 11-year-olds, I identified with the life of the rapping pimp."
