TwinTurbo.NET: Nissan 300ZX forum - MAximum boost does not mean maximum power BTW.
Subject MAximum boost does not mean maximum power BTW.
Posted by AshsZ (FABio) on January 29, 2003 at 7:55 PM
  This message has been viewed 107 times.
In Reply To how much boost can a stock engine handle with stock turbos? (n/m) posted by RookieZTT on January 29, 2003 at 06:41 PM
Message I've proven (to myself) that at 19psi I make less power than I do at 16psi. It is because at 19psi, the ignition timing has to be so retarded to avoid detonation, that the power drops more than what you can make at 16psi running more advanced timing (more efficient, cooler and denser charge). When I went from 19psi at 25 degrees of timing to 16psi at 33 degrees of timing, I went from low 13's to mid/upper 12's in the 1/4.
[ ashleypowers.com ]
[ agpowers@bellsouth.net ]
[ Zemulator Information Sheet ]
When pigs dance, you better get it on video...
"You never really learn to swear until you learn to drive."
-George Carlin
