TwinTurbo.NET: Nissan 300ZX forum - it does, speed sensor is on the tranny (n/m)
Snoguitar
on January 08, 2003 at 12:01 AM
then why doesnt the speedo go up when tires spin (n/m)
posted by Tennyson (ATL)
on January 07, 2003 at 11:50 PM
Any problem using 225/45s instead of 225/50s on front of TT?
flash-to-pass
23:40:12 01/07/03
only on the speedo (n/m)
Tennyson (ATL)
23:43:49 01/07/03
From a 5mm shorter sidewall?
flash-to-pass
23:44:59 01/07/03
why did you put "n/m" in your message body? (n/m)
Snoguitar
00:04:47 01/08/03
the difference is actually 11.25mm (n/m)
Luke@tirerack
07:36:42 01/08/03
speedo no see the fronts (n/m)
SactoTodd
23:48:33 01/07/03
Tennyson (ATL)
23:50:14 01/07/03
it does, speed sensor is on the tranny (n/m) -
Snoguitar
00:01:32 01/08/03
i thought was just for the 20mph lockout in first gear?
Tennyson (ATL)
00:04:54 01/08/03
It wont change speedo calibrations but it will>>>
TwinTurboPoweredZ
23:47:26 01/07/03
ABS reads gaps in the rotors (n/m)
Tennyson (ATL)
23:49:21 01/07/03
Then why does the owners manual say do not use different>>
TwinTurboPoweredZ
23:54:36 01/07/03
b/c different tire diameters will affect rotations
Tennyson (ATL)
00:00:09 01/08/03
theres a reason for all 4 tires to be all the same height>
TwinTurboPoweredZ
00:08:27 01/08/03
Re: b/c different tire diameters will affect rotations
SactoTodd
00:11:51 01/08/03
Thank you for clarifying that with him Todd. :) (n/m)
TwinTurboPoweredZ
00:18:23 01/08/03
225/45
dlinn
00:28:43 01/08/03
I think he was talking about 16" wheels not 18" (n/m)
TwinTurboPoweredZ
00:33:07 01/08/03
Yes...16" not 18". So the change isn't worth the trouble (n/m)
flash-to-pass
01:18:14 01/08/03
Whenever you change wheels or tires, make sure that>
TwinTurboPoweredZ
00:28:47 01/08/03
load capacity issues
Luke@tirerack
07:34:40 01/08/03
