TwinTurbo.NET: Nissan 300ZX forum - Maxima has VG30DE motor and used twin electric fans instead
Carlos Ramirez
on December 25, 2002 at 9:10 PM
What's a Maxima?
posted by AshsZ (FABio)
on December 25, 2002 at 09:03 PM
of clutch fan the idea is that you get less parastic loss you know like a UR pulley :-)
Is an ignition upgrade worth it ?........
au7385
20:22:57 12/25/02
no. maybe DOT drag tires. and why have the dual fans in your
Halo Z
20:43:21 12/25/02
Re: no. maybe DOT drag tires. and why have the dual fans in your
au7385
20:47:51 12/25/02
Get some Nitrous.. And don't be a wuss like HaloZ
Carlos Ramirez
20:51:20 12/25/02
Re: Get some Nitrous.. And don't be a wuss like HaloZ
au7385
20:57:32 12/25/02
Well cams in that case then.. Maybe water injection.
Carlos Ramirez
21:00:02 12/25/02
Well, here's some interesting info. The ECU's program has
AshsZ (King of FAB)
20:51:49 12/25/02
Re: Well, here's some interesting info. The ECU's program has
au7385
20:56:09 12/25/02
So for those with the ignition, gapping down to .035 is...
robbyg
23:21:34 12/25/02
What boost level are you running with that setup? (n/m)
AshsZ (FABio)
23:48:56 12/25/02
15psi, creeps up to 16psi with the nitrous. stock turbos...
robbyg
11:07:24 12/26/02
You had to regap for 17psi??
Dallas DamonZ
08:47:14 12/26/02
Ash do you know about the maxima engine bay fan conversion?
au7385
21:01:30 12/25/02
What's a Maxima?
AshsZ (FABio)
21:03:34 12/25/02
Re: What's a Maxima?
au7385
21:08:05 12/25/02
Maxima has VG30DE motor and used twin electric fans instead -
Carlos Ramirez
21:10:17 12/25/02
VE30DE. (n/m)
Maximamike
21:11:41 12/25/02
what's the difference between them?
Marshall
01:15:33 12/26/02
aluminum block on VE (n/m)
Chip(GinnMotorsports)
10:53:22 12/26/02
VE has iron block, aluminum heads..
Maximamike
13:34:19 12/26/02
Learn something new everyday. (n/m)
15:00:23 12/26/02
Re: Maxima has VG30DE motor and used twin electric fans instead
au7385
21:15:48 12/25/02
Ah. Hmmm, I'd be concerned with volume of airflow>
AshsZ (FABio)
21:16:06 12/25/02
why wont someone just stick a 'blackmagic' fan on it
niXit
21:21:41 12/25/02
http://www.flex-a-lite.com/auto/blackmag.htm
niXit
21:26:17 12/25/02
I have a blackmagic fan and tried to run it...
TARGETZ
00:23:00 12/26/02
Re: Ah. Hmmm, I'd be concerned with volume of airflow>
au7385
21:21:49 12/25/02
for christs sakes newbie, for xmas, please punctuate. (n/m)
niXit
21:24:04 12/25/02
oh please god....shoot me now. =\ (n/m)
Halo Z
21:26:33 12/25/02
Re: for christs sakes newbie, for xmas, please punctuate.
au7385
21:26:33 12/25/02
Lets think about this for a minute..
Carlos Ramirez
21:28:18 12/25/02
Halo, what did your car run at the track? (n/m)
au7385
21:30:31 12/25/02
i have had a fuel problem. 14.8 is my best.
Halo Z
21:34:43 12/25/02
Re: i have had a fuel problem. 14.8 is my best.
au7385
21:37:02 12/25/02
don't the clutch give out at a certain RPM? (n/m)
Halo Z
21:32:55 12/25/02
i had a flex-a-lite 210 on my z31 turbo..
jtmiller02 (gamecock)
21:51:12 12/25/02
Since no one mentioned it, here's when you may need it>>>
SeedyROM
00:40:07 12/26/02
