TwinTurbo.NET: Nissan 300ZX forum - Wilwood Brakes and largest opening on a front fascia?
Subject Wilwood Brakes and largest opening on a front fascia?
Posted by Carlos Ramirez on December 01, 2002 at 5:55 PM
  This message has been viewed 460 times.
Message I am wondering if anyone know what happened to the Wilwood's brake kit that was posted a bit ago. It was like 1800 for fronts and 700 for the rear. Seems like it was the best deal on brakes as the front was using 6 piston caliper and a 13.1 rotor and the rears had something like 12.8 Rotor with a two piston caliper and retained the e-brake?
Also I was thinking of replacing my front fascia with something that had a bigger openning for the FMIC. The only one I can really think of that has a large enough opening is the Bomex one? Anyone have any thoughs on one that has a larger opening?
From this pics you can sort of tell that on top 3 of the cooling fin and 4 of the plate rows are blocked, and on the bottom 3 rows of fins and plates are also blocked. While this is not all that bad I am sure it will get plenty of air I want to maximize my cooling factor.
