TwinTurbo.NET: Nissan 300ZX forum - Running stock engine? stock compression?
Subject Running stock engine? stock compression?
Posted by degradated on October 04, 2002 at 11:47 PM
  This message has been viewed 65 times.
In Reply To ANOTHER UPDATE: Fresh compression numbers >>> posted by Greg (Dallas) on October 04, 2002 at 09:27 PM
Message Those numbers are pretty low. Below spec in 4 and 6. Perhaps your rings are going? Don't you have only 41k miles or something?
It's weird, because I checked my compression on my 41k Z a week ago and got very similar numbers, but found out later that I did the procedure wrong and didn't open the throttle bodies. Ended up with 140-145 across the board instead.
But it says that you did open the throttle bodies, so I'm not sure.
