TwinTurbo.NET: Nissan 300ZX forum - The difference between stock brakes and upgraded brakes is
Subject The difference between stock brakes and upgraded brakes is
Posted by PLEAZURE in CA (SD) on August 27, 2002 at 4:53 PM
  This message has been viewed 43 times.
In Reply To You're getting caught up in the details. posted by Marshall on August 27, 2002 at 03:34 PM
Message mainly, in the capacity of the bigger rotors and pads to dissipate the heat created from the kinetic energy transformation ... the more heat you dissipate the better braking you have and less fading you will get.
So you have 2 advantages here ... faster heat dissipation (shorter stopping distance) and less fading (might save your ass).
It's as simple as that ... and if you're using Z rated tires .. they have so much grip, you wont need to lock your tires up to stop it ... the ABS will do it's job.
Matt
91TT Aztec Red stg III+
MY PLEAZURE
