TwinTurbo.NET: Nissan 300ZX forum - it's very easy to brake like the ignition coil connectors
Subject it's very easy to brake like the ignition coil connectors
Posted by PLEAZURE in CA (SD) on August 26, 2002 at 5:25 PM
  This message has been viewed 49 times.
In Reply To HELP NEEDED ASAP!!! what is that metal circle with a plug posted by Pure-Evil on August 26, 2002 at 04:09 PM
Message because the plastic with the heat will dry out and becomes brittle and will crack when you puch it down to unplug it ..the same way the ignition coil connectors break when you try to remove them .. also if that thing is not on tight and it moves even a fraction of a mm it will mess up your timing
Matt
91TT Aztec Red stg III+
MY PLEAZURE
