TwinTurbo.NET: Nissan 300ZX forum - I removed the temp sensor to let air escape and I also
MikeH(Twin GT35BB Incon Z)
on August 13, 2002 at 4:59 PM
Well, I tried to make sure >>>
posted by KaZ (jTTfz) NoVa
on August 13, 2002 at 04:52 PM
squeeze the upper hose to let air bubbles out with the cap off.
Interesting results after Koyo on hot day... (warn = book)
KaZ (jTTfz) NoVa
16:33:28 08/13/02
Should have gotten the HOWE :P (n/m)
Snoguitar
16:40:28 08/13/02
Its not that much bigger... I think its just my Z >>>
KaZ (jTTfz) NoVa
16:42:25 08/13/02
Actually it probably would have. In 115 degree weather
wildstar
17:12:36 08/13/02
was waiting for you to post ;) (n/m)
Snoguitar
17:22:13 08/13/02
Well I'm not saying it wouldn't have completely not >>>
KaZ (jTTfz) NoVa
17:31:21 08/13/02
you just need a vented hood from strictlyZ
3 double-0 ZX (Va Bch)
18:25:30 08/13/02
Don't think that is the answer, though it might help! (n/m)
KaZ (jTTfz) NoVa
22:14:21 08/13/02
Well...
wildstar
19:36:25 08/13/02
It actually is that much bigger >>
FNFAZTT
17:51:28 08/13/02
Re: Interesting results after Koyo on hot day... (warn = bo
Dallas DamonZ
16:45:42 08/13/02
Yes, possible that you got an air pocket in there. (n/m)
teahead
16:49:25 08/13/02
KaZ (jTTfz) NoVa
16:52:43 08/13/02
I removed the temp sensor to let air escape and I also -
16:59:21 08/13/02
did you jack up the front end to get the air to the top
sbsTT(MD)
17:00:44 08/13/02
Yes, nose was about a foot or so in the air >>>
KaZ (jTTfz) NoVa
17:02:51 08/13/02
I'm with Damon on this - seen it happen with just >>>
Mike (Austin)
11:30:28 08/14/02
That the same behavior of my stock one. From observation
Arturo C.
16:51:05 08/13/02
Top is 232? You mean the mark "Below" H? >>>
KaZ (jTTfz) NoVa
16:57:55 08/13/02
could your water/antifeeze mix be a little lean? (n/m)
TonyD(90Z32TT)
16:51:44 08/13/02
Well, some recommended running completely water with wetter
KaZ (jTTfz) NoVa
16:54:45 08/13/02
took me 4 days to burp my cooling system
voodoo
17:00:05 08/13/02
you should have went 50/50 (n/m)
TARGETZ
18:14:01 08/13/02
50/50 is overkill, water actually does most of the cooling. (n/m)
Fly'n Z
18:23:50 08/13/02
nope...
TARGETZ
18:26:33 08/13/02
No it doesn't. (n/m)
wykked
19:28:16 08/13/02
Wrong.
Chip(GinnMotorsports)
19:39:12 08/13/02
you are wrong
aliaZ
22:38:08 08/13/02
Check compression, may be HG.
18:22:36 08/13/02
Just did the other day 140 on most cylinders >>>
KaZ (jTTfz) NoVa
19:04:47 08/13/02
Stock have been holding up fine to high boost, but
19:37:49 08/13/02
I bet chip is right on the mark. Could be a
Deca Z
18:54:23 08/13/02
Checked coolant level, right at the top >>.
KaZ (jTTfz) NoVa
19:08:56 08/13/02
Should have gotten the HOWE... (n/m)
Jake H
19:47:54 08/13/02
they never listen... (n/m)
HalfnHalf702(winner)
19:55:48 08/13/02
sure it's not just a screwy new temp sensor?
Altersys
20:24:13 08/13/02
thats what i was thinking (n/m)
Chris(NJ)=driveshaft king
21:18:43 08/13/02
What do you mean by the temp sensor exactly?
KaZ (jTTfz) NoVa
22:13:54 08/13/02
Re: What do you mean by the temp sensor exactly?
Altersys
12:40:47 08/14/02
