TwinTurbo.NET: Nissan 300ZX forum - Horrible negative camber, best priced solution to fix?
Subject Horrible negative camber, best priced solution to fix?
Posted by Fokker on July 11, 2002 at 4:49 PM
  This message has been viewed 110 times.
Message yeah i have horrible negative camber for the front wheels. probably just sagging springs but in any case i took out my stock wheels and had new ones put on. on the stock fronts, the wires are showing in hte inside edge of the tire but they still have like 40% tread left in the middle and outside. this is bad. i know of hte solutions, either the adjutable a-arms from stlllen or the washers or plates (300degree camber kit). is the stillen kit still ridiculously expensive? where can i get them for the cheapest price. would it be recommended to install the 300 degree kit even tho it was designed for the eibach .8 drop. if my springs have sagged .8 inches then would it be the same characteristics as if i actaully just had the eibach springs.. i basically spent a lot of money on new wheels and tires and i just want to get the camber fixed so i don't have to keep replacing hte tires. thanks a lot
