| Message |
You can do it in a weekend if you have help. replaced all the gaskets and lines. Too many to list. I remove the intake manifold first. Hook the chains to the gold side brackets. Remove the A/C put leave on car. Don't crack open the lines. Remove, the power steering and leave on the car.
Arizona'a most powerful 600HP 15 second Z More powerful than a stock TT , slower than an NA Dynoed 515 rwhp and 420 ft.lbs @ 16psi 89 degrees. 533 rwhp and 450 ft. lbs @19 psi and slipping clutch and heat soaked motor , 85 degrees.
