TwinTurbo.NET: Nissan 300ZX forum - Arizona Heat should be back and running after 9 months
Subject Arizona Heat should be back and running after 9 months
Posted by MikeH(Twin GT35BB Incon Z) on March 28, 2002 at 3:19 PM
  This message has been viewed 145 times.
Message My engine only has 3000 mile on it. Did leak down test and it was between 5 -2 % leak down on cold motor with forged pistons.
Have the engine back in and hooked up. Just have to install my howe radiator and oil preluber and some minor things.
I have the fuel lines done -6 and - 8 steel braid. Parallel feed modifed fuel rails.
New RPS pressure plate and six puck sintered bronze from Mueller. Running the stock single pump till next week . I have to drive it to the fabricator to do the dual walbro fuel pump upgrade.
I will dyno tune again up to 25psi on my stillen intercoolers.
I am expecting my UAS FMIC and should be good for at least 2 bar.
Mike
Arizona'a most powerful 600HP 15 second Z
More powerful than a stock TT , slower than an NA
Dynoed 515 rwhp and 420 ft.lbs @ 16psi 89 degrees.
533 rwhp and 450 ft. lbs @19 psi and slipping clutch
and heat soaked motor , 85 degrees.
