TwinTurbo.NET: Nissan 300ZX forum - exhaust leak? leaking turbo? Screwed up Dyno? Bad Plugs? (n/m)
Carlos Ramirez
on October 09, 2000 at 3:54 PM
question about dyno result....>>
posted by NONE
on October 09, 2000 at 03:15 PM
NONE
15:15:48 10/09/00
ouch thats hella low (n/m)
genic (pimpadelic)
15:16:49 10/09/00
Something's definitely wrong. Check your compression lately? (n/m)
John Y(Houston)
15:18:53 10/09/00
checked it before mods AOK... (n/m)
NONE
15:23:22 10/09/00
run ecu diag? any error codes? timing set properly?>
twinz
15:20:48 10/09/00
Re:checked timing,no codes (n/m)
NONE
15:29:05 10/09/00
maybe one of your main hoses is loose... on the turbos
Bernie
15:32:57 10/09/00
I checked boost with the dyno at time of run.. (n/m)
NONE
15:38:38 10/09/00
You can still hit PSI and leak CFM (n/m)
SteAmyZ (T-Top Bag Man)
15:49:30 10/09/00
This I didnt know I will check,If >>>
NONE
15:57:48 10/09/00
This is they way you can tell>>>
16:00:39 10/09/00
Re: This is they way you can tell>>>
NONE
16:07:14 10/09/00
yup.....sounds like a boost leak to me
SteAmyZ (T-Top Bag Whore)
16:15:59 10/09/00
The car was bulit at...
NONE
16:22:58 10/09/00
exhaust leak? leaking turbo? Screwed up Dyno? Bad Plugs? (n/m) -
Carlos Ramirez
15:54:01 10/09/00
check your plugs...and
Carlos Ramirez
15:54:31 10/09/00
Fourth gear run need to check plugs (n/m)
NONE
16:01:05 10/09/00
Can you post your dyno sheet? You can tell sometimes
Spongerider
16:04:03 10/09/00
cant post but I will fax if anyone can help (n/m)
NONE
16:10:27 10/09/00
Sorry dude but I smell a troll. Why can't you post your
J-Z91
17:44:58 10/09/00
Uhh... cause he has no scanner? (n/m)
mfh {Z kid}
18:36:45 10/09/00
Sport500 are POS. You have test pipes and gutted precats? (n/m)
MikeH(Phoenix)
16:25:00 10/09/00
Gutted cats no test pipes (n/m)
NONE
16:27:22 10/09/00
POS should still make some power lol... (n/m)
NONE
16:30:36 10/09/00
check timing and get test pipes. n/m)
MikeH(Phoenix)
16:47:49 10/09/00
checked timing ,pipes make a 100hp diffrence?? (n/m)
NONE
16:55:08 10/09/00
yes, you are choking off the engine with the cats (n/m)
MikeH(Phoenix)
17:42:31 10/09/00
at least 30-40hp difference depending upon boost level. (n/m)
twinz
13:56:12 10/10/00
He's not lying ->
MikeeZ
08:28:53 10/10/00
