TwinTurbo.NET: Nissan 300ZX forum - It is a common knowledge, on how compression ratio's are
Subject It is a common knowledge, on how compression ratio's are
Posted by SWEET Z on March 17, 2002 at 11:28 PM
  This message has been viewed 41 times.
In Reply To Thanks for the input, gotta couple Q's? posted by AshsZ (Fab Whore, Ph.D) on March 17, 2002 at 10:05 PM
Message the higher your compression ratio is the closer the piston is to the head at TDC,or top dead center.
I don't recall the na but I think it is like 10.5/1, and I know for a fact that the TT is 8.5/1.
if you used TT pistons then they arn's going to be as high,
the head doesn't matter cause the block still has the same deck highth. The only diff on the head if I recall is cause of the valve size, I am not possitive on that one but I am sure that is what I remember..
If you need to talk about it email me with your # and I will call you.
later,
Danny
