TwinTurbo.NET: Nissan 300ZX forum - H2O temp. sensor on front of engine>>>
SirpriZ
on January 15, 2002 at 12:41 AM
Z starts hard, turns over but takes a while to fire..
posted by -MaineZ-
on January 15, 2002 at 12:15 AM
check the connection to make sure its clean, also try wiggling the sucker and see if the pronge is intact. I had the same hard to start problem and found a bad sensor...replaced and problem solved. Good luck, Mark
-MaineZ-
00:15:34 01/15/02
don't press gas when you start it...it's fuel injected-->
ZFreak (Link Whore)
00:17:10 01/15/02
60k tune up/filter is new, wont even fire unless I pump gas. (n/m)
-MaineZ-
00:22:12 01/15/02
Make sure fuel filter isn't on backwards (n/m)
ImTheDevil
00:28:12 01/15/02
This only happens when car has been sitting in cold. (n/m)
-MaineZ-
00:34:21 01/15/02
H2O temp. sensor on front of engine>>> -
SirpriZ
00:41:11 01/15/02
Service manual says Injector Leakage
Patnessyo
10:14:04 01/15/02
