TwinTurbo.NET: Nissan 300ZX forum - should have tested befoe head removed. When head is>
RT
on December 12, 2001 at 4:13 PM
cant find problem with 40 psi cylinder..
posted by NIXTA TTZ
on December 12, 2001 at 04:02 PM
on put some oil in and seeif compresion rises. if it does it is rings or cylinder(oil helps block it). if not it was valves.
NIXTA TTZ
16:02:26 12/12/01
should have tested befoe head removed. When head is> -
RT
16:13:54 12/12/01
isnt he correct tho?>>
NIXTA TTZ
16:28:48 12/12/01
No one cylinder being down unless piston has hole will>>
RT
16:40:08 12/12/01
Re: No one cylinder being down unless piston has hole will>> (n/m)
Z 6370 (Fab Hoe)
18:53:57 12/12/01
I had the same test, and it narrowed down to the valves.
KingRamaZX
18:10:04 12/12/01
Looks like my valves then. whew.........Thank God. (n/m)
KingRamaZX
18:04:25 12/12/01
You should have done a leak down test also (n/m)
MikeH(Phoenix)
16:41:40 12/12/01
what exactly is a leakdown test?
NIXTA TTZ
16:48:34 12/12/01
Your pressurize the cylinder at TDC with compressed
MikeH(Phoenix)
17:02:01 12/12/01
we did a leakdown.. came up 90%.. (n/m)
NIXTA TTZ
17:43:23 12/12/01
