TwinTurbo.NET: Nissan 300ZX forum - Turbos use less power from the engine.....
Aseem
on November 18, 2001 at 8:25 PM
SZR: What is better? 9 psi of turbo, or 9 psi of S.charger.
posted by nixit(da][as)
on November 18, 2001 at 08:14 PM
Approx. 5-10% for turbos and up to 30% for superchargers.
Aseem 95TT
nixit(da][as)
20:14:25 11/18/01
Supercharger will have more low end but turbos are>>
CarlCuro (busted...again)
20:17:56 11/18/01
Turbos are more efficient than SC's.
AshsZ (Retired)
20:18:13 11/18/01
going with that info and the fact that he has a Corvette>>>
sbsTT(MD)
21:20:38 11/18/01
SC cause of no lag. (n/m)
Spongerider
20:18:45 11/18/01
Ditto. No lag. Better bottom end. But they do blow-off>>>>>>
uneaZy rider
00:00:03 11/19/01
Shouldn't it depend on the mass air flow rate?(m with a dot)
timz
20:19:07 11/18/01
2.3/4" single intake. KnN filter. stock t/b's
nixit(da][as)
20:24:13 11/18/01
I'll go supercharged. no lag, easy to install. (n/m)
timz
20:26:34 11/18/01
My 2 pennies SC puts drag on engine turbos do not:) (n/m)
RT
20:22:16 11/18/01
yep. (n/m)
HaloZ²
20:25:07 11/18/01
turbos also put drag on the engine (the exhaust)
Marshall
21:29:09 11/18/01
Here's your answer
TTony
20:24:56 11/18/01
converted to auto. no off roading, but 4 wheel street racing (n/m)
nixit(da][as)
20:27:38 11/18/01
Plus SC will run cooler than turbos(hot exhaust)reliability? (n/m)
RT
20:29:36 11/18/01
but SC always runs. Turbo's are there when needed. :-) (n/m)
TTony
21:28:22 11/18/01
Turbos use less power from the engine..... -
Aseem
20:25:55 11/18/01
this particular SC produces much more power then the td04. (n/m)
nixit(da][as)
20:29:34 11/18/01
Ask Yvonne about this stuff she's great with the tech advice (n/m)
Aseem
20:33:08 11/18/01
Or Jim Nasyum.... :/ (n/m)
nixit(da][as)
20:34:10 11/18/01
Re: Or Pete Moss... (n/m)
Aseem
20:35:44 11/18/01
You obviously know what your doing........
Aseem
20:44:43 11/18/01
Not all superchargers are tuned for low end. Its true that
crunk300zxtt
20:43:02 11/18/01
hmmm.. id go with the turbo..
NIXTA TTZ
20:43:21 11/18/01
yeah it seems for any 4x4 application you need low power
BDz32 (FL)
20:48:54 11/18/01
thats what creeper gears are for..
NIXTA TTZ
21:18:14 11/18/01
i'm thinking you should get turbos... this is why (inside)
TTony
21:37:03 11/18/01
Compression ratio on SC motors would make 9spi high...
ZBlacktt
21:18:43 11/18/01
supercharger.....
KILLR300ZX
21:56:38 11/18/01
Use both Turbo and SC (n/m)
zdreamer
22:39:10 11/18/01
sounds like the HKS toyota MR2 (n/m)
willflow
22:48:35 11/18/01
I hope you do a new roll cage first! DEATH TRAP! LoL. (n/m)
DamonH 90TT
04:03:28 11/19/01
he is hardcore, probably will stick his head out
genic
08:27:42 11/19/01
