TwinTurbo.NET: Nissan 300ZX forum - Best way to set is to get a vacuum gauge ($20 at pep boys)
Subject Best way to set is to get a vacuum gauge ($20 at pep boys)
Posted by Bernie on September 18, 2000 at 7:53 PM
  This message has been viewed 29 times.
In Reply To sounds dangerous, but parking brake/foot brake then >> posted by nixit(da][as) on September 18, 2000 at 07:42 PM
Message and pull the BOV off, attach the gauge to where the vacuum hose connects and watch the diaphragm of the BOV move when you reach a certain vacuum level. Set the BOV's to 22 in Hg vacuum before they open. If they're set weaker than that, they will bleed to early and may even open at idle sometimes.
Another way you can do it is to have a buddy rev the engine to build boost... he has to pulse it, like ABS, in order to get the boost built up. (or use the launch control button on the Racelogic unit you should have bought... LOL!) The only problem is it's doubtful that he'd be able to get full boost doing this... and you really need to get full boost because it's the high psi that's probably causing the leak.
Lastly, you can just tighten the screw to set the spring rate higher gradually and by trial and error, you'll hit the point where you no longer hear the bleeding sound... then tighten it just a little bit more than that.
Good luck!
Bernie
Authorized sales rep for...
For more information, pricing, or to purchase a system,
feel free to e-mail me: bhsiao@newssun.med.miami.edu
or visit the website
