TwinTurbo.NET: Nissan 300ZX forum - no clutch pressure usually means either >>
Subject no clutch pressure usually means either >>
Posted by maverick (NYC) on September 07, 2001 at 7:32 PM
  This message has been viewed 51 times.
In Reply To Just got royally shafted by dealer buying ttz. Any input on posted by Xi0nX4 (ohio) on September 07, 2001 at 06:13 PM
Message the master cylinder or the slave cylinder is shot. my slave cylinder was completely shot and i had to fight it to put it into gear after pumping the clutch many times when i lost pressure. even though it wasn't visually leaking oil, it was a bad part. you mention that the slave has been replaced? maybe its as simple as the clutch master cylinder? its an easy do it yourself swap and the part will be less than $50. good luck bro.
mike
zxredline@yahoo.com
1990 PearlGold Stage3 NA
