TwinTurbo.NET: Nissan 300ZX forum - Simple solution when u hydrolock an engine----->
Subject Simple solution when u hydrolock an engine----->
Posted by TRUOMEGA on September 11, 2000 at 9:30 PM
  This message has been viewed 23 times.
In Reply To Will Insurance pay for it if you Hydolock your engine??? n/m posted by ZMEGOBY on September 11, 2000 at 11:49 AM
Message I go to an aviation school and when planes get hydrolocked....what they tell u to do is remove all spark plugs and crank the engine. All the water will spue out ur cylinder chamber. When u see that most of the water is out. Put spark plugs back in and start motor. There should be enough room for ur piston to move up and down and when u get ignition all the water evaporates with the exhaust. This is all assuming u didnt do any permanent damage to ur engine. Good luck.
