TwinTurbo.NET: Nissan 300ZX forum - Map light tap has been fine for about 20 years now. (n/m)
not4resaleZ
on November 06, 2013 at 12:35 PM
A lot of people tap in the power near the map light
posted by Summeronthechain (MN)
on November 06, 2013 at 08:47 AM
valentine one install
PYROhafe
07:37:10 11/06/13
Using a fuse tap is easiest, or...
ThisIsSparTTa
08:46:42 11/06/13
"Just tap off a circuit that is on with the car"
The Hawk
09:04:34 11/06/13
I used the fuse for the radio.
AHos(Chicago)
09:48:52 11/06/13
Pretty sure I tapped off of Radio fuse as well.
ThisIsSparTTa
13:21:45 11/06/13
thanks!
PYROhafe
09:48:54 11/06/13
This is how I did it, connected to a switched power supply
ThunderZ
21:30:47 11/06/13
08:47:08 11/06/13
Yea I've seen quite a few tap into the map light (n/m)
Piranha
10:52:53 11/06/13
Map light tap has been fine for about 20 years now. (n/m) -
not4resaleZ
12:35:32 11/06/13
Yup, just remember to shut the detector off or it will drain
ZinnZ32
16:10:28 11/06/13
Taped into fuse in driver’s kick panel.
SilverZXTT(CO)
14:53:52 11/06/13
do it once, do it right
fuzzymonkey
15:55:25 11/06/13
This is beyond overkill...
ThisIsSparTTa
08:47:52 11/07/13
No it's not at all actually...
ttsmokin
10:23:45 11/07/13
It is beyond overkill because the current draw for the radar
MixManMash
11:12:01 11/07/13
Agreed, using an add-a-circuit with a fuse equal to the
11:24:28 11/07/13
Again, do it once, do it right.
fuzzymonkey
16:01:22 11/07/13
I disagree.
Antihero
16:08:42 11/07/13
see my reply "With a relay" below. (n/m)
fuzzymonkey
16:13:33 11/07/13
lol. Go ahead, argue with an electrical engineer.
MixManMash
16:34:33 11/07/13
Basic electrical engineering knowledge disagrees with you
ThisIsSparTTa
14:54:10 11/07/13
and then how are you going to make the new run switched?
Antihero
12:01:17 11/07/13
With a relay.
fuzzymonkey
16:11:14 11/07/13
I still disagree with the unnecesary home run.
Antihero
08:38:19 11/08/13
THIS...
240Z FeO2
23:14:21 11/06/13
I have no idea whether this is relevant, or helps, but I'll
zellamay
23:41:08 11/06/13
HA! great - you can drive in front of me! (n/m)
SuparexTT
14:05:53 11/07/13
