TwinTurbo.NET: Nissan 300ZX forum - To answer Adam's question and to give a little more info.
Subject To answer Adam's question and to give a little more info.
Posted by DVDBURN (MD) on October 27, 2013 at 11:44 PM
  This message has been viewed 234 times.
In Reply To What if ? posted by DVDBURN (MD) on October 27, 2013 at 09:45 PM
Message It can be used with any car that you can tap into the ECU inputs. The app can also be used with any Android device that has bluetooth, not just the Samsung Galaxy Gear. Here is a list of the things it will be able to monitor as related to the Z32. How many you connect it to will be up to you although I HAVE thought about a complete setup that includes a prewired field harness to make it plug and play.
Check Engine
Battery
Sensor Power
TPS Idle Power
Start Signal
IGN Switch
ECCS/IGN Relay
TPS Idle Switch
Neutral Switch
Speed
RPM
TPS
MAF Voltage
Water Temp
Fuel Temp
O2 left
O2 right
EGR Temp
Fuel Pump Relay
Fuel Pump CTL
Fuel Pump CTL (TT)
Waste Gate Solenoid
P/S Pressure Switch
Fan Relay (Main)
Fan Relay (Sub)
IACV-AAC Valve
IACV-FICD Solenoid
PRVR Solenoid
VTC Solenoid
EGR Solenoid
AIV Solenoid
CAS 1 Deg
CAS 120 Deg
A/C Relay DPS
www.mytwinturbo.com
Nissan Data Voice on YouTube
