| In the instructions it says: ".. to splice both the green and black wires to a single ground wire on the ECU. Splice the GREEN wire closest to the ECU connector and splice the BLACK wire 1/2" further away. Sounds odd, but is rather critical." However it never goes on to explain why it is critical to splice these two wires a half inch apart or one closer to the ECU than the other. The Apexi instructions don't make any mention of this either. Anyone know why this was listed in the instructions or what would happen if you spliced both wires to the same spot?
