TwinTurbo.NET: Nissan 300ZX forum - 1Used steel rods to replace a few of the head bolts. Gasket
Subject 1Used steel rods to replace a few of the head bolts. Gasket
Posted by LivinTheDream on September 09, 2013 at 6:56 PM
  This message has been viewed 428 times.
In Reply To Beggest Noob Mistakes! Post them up! posted by fuzzymonkey on September 09, 2013 at 01:27 PM
Message blew on the first crank.
2. I used some black bullshit from permatex (Form-A-GasketĀ® No. 2 Sealant) on my valve covers. Shit melted. In the process of changing it out to Ultra Copper now.
3. Jacked the car up with a scissor jack and had a jackstand under it. Well scissor jack leaned and the jack stand went through the floor. Ive had a couple cars fall from scissors jacks so i recently got the Pittsburgh 2ton low profile hydraulic jack.
3. Hooked up the fuel lines backwards on a newly installed engine. Wasnt bad though because I looked over EVERYTHING before I figured it out. So learned some tricks and felt good that everything was tip top.
4. Installed the timing belt washer backwards. Ate up the timing belt.
5. Put the wrong banjo bolts in the turbo oil lines.
6. Used a razor to straighten bend radiator fins and put 3 tiny ass holes in 3 of the tubes.
7. Attempted to started the car with the T junction/pop filter still off and sucked a bag down to the turbo.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
