TwinTurbo.NET: Nissan 300ZX forum - Re: Stuck lifter may cause LOSS of compression
Subject Re: Stuck lifter may cause LOSS of compression
Posted by slicktt on August 22, 2013 at 12:40 PM
  This message has been viewed 226 times.
In Reply To Stuck lifter may cause LOSS of compression posted by ZXoltan on August 22, 2013 at 12:12 PM
Message Camshaft profiles actually have something designed in them called overlap. During this time both intake and exhaust valves are open somewhat. If the exhaust valves are sticking shut or not fully opening or if the intake valves shut early it can actually raise compression especially at cranking speed. Because the overlap duration is decreased and this forces up pressure. Overlap only helps airflow at higher engine speeds. I have seen it happen more than once.
1995 Slicktop TwinTurbo
HREF="http://www.flickr.com/photos/100257008@N08/sets/721576350
44711353/">Z32 Build
