TwinTurbo.NET: Nissan 300ZX forum - Yes he did but he did replace the main and rod bearings
Evan_Wright (Ca)
on August 21, 2013 at 12:32 PM
If it isn't broke, don't fix it, lol. Install the parts on
posted by TTZ2NV(EPTmotorsports)
on August 21, 2013 at 12:00 PM
and valve stem seals last year. I would think Zvil's engine would hold up well with 28rs's on pump gas level boost. May want to consider building the engine if you plan on maxing the turbos out on some sort of high octane fuel.
repost -Engine rebuild?
Zvil (FL)
11:49:19 08/21/13
12:00:47 08/21/13
Yes he did but he did replace the main and rod bearings -
Evan_Wright (Ca)
12:32:48 08/21/13
dont touch it the engine.
rmp459
12:09:21 08/21/13
Repost...? When/where did you post originally?
ZXoltan
14:18:48 08/21/13
repost because there are several "should I rebuild" posts
Zvil (FL)
15:36:08 08/21/13
no way I would do it
15:07:06 08/21/13
Replace the rod bearings at a minimum. (n/m)
michaell32 (FL)
15:09:58 08/21/13
Re: repost -Engine rebuild?
slicktt
09:59:34 08/22/13
Need to totally disassemble to check ring gaps.
ZXoltan
10:24:49 08/22/13
Re: Need to totally disassemble to check ring gaps.
slicktt
10:35:59 08/22/13
Stuck lifter may cause LOSS of compression
ZXoltan
12:12:24 08/22/13
that's kinda what I was poking at
Zvil (FL)
12:20:47 08/22/13
Re: Stuck lifter may cause LOSS of compression
slicktt
12:40:11 08/22/13
Would an oil pressure test and oil analysis be enough?
Zvil (FL)
12:26:38 08/22/13
Your first sentence is a fairly common sentiment here (which
12:00:49 08/22/13
my example is a poor one
12:06:34 08/22/13
Re: Your first sentence is a fairly common sentiment here (which
slicktt
12:47:43 08/22/13
I will admit though
slicktt
12:51:37 08/22/13
this is my point
15:44:45 08/22/13
What Mitch from EPRacing has to say.
LivinTheDream
23:01:21 08/22/13
More:
LivinTheDream
23:10:22 08/22/13
If your as meticulous as u say and I am as well I would
LivinTheDream
23:14:23 08/22/13
