all this work is getting done in the shop already wanting to know all the positives and gains I should expect to gain. how much hp increase around? Arp VG30 main and head stud kit (Nissan 300zx) Nissan 300zx OEM Hydraulic valve lifters (24 new) Wiseco Pistons 88mm over stock 87 Eagle/SCAT H Beam Rods ARP Rod Studs New Moly Coated Race Spec Main bearings installed New Moly Coated Race Spec Rod bearings installed New OEM Valve stem seals New OEM Cam Seals New OEM Head Gaskets New OEM Oil Pump New OEM Oil Pump Gasket (Engine work) ceramic/moly piston coating Block Inspected and acid dipped Block redecked Block water passage bored out for more water to back cylinders Block Bored and Honed Crank center weight tig welded into place Crank balanced Block prepped and assembled Heads inspected and cleaned Heads Pressure Tested Heads redecked Ported exhaust and intake runners 5 angle radius cut valve job Valve heights set
engine Upgrades question on all benifits - mr300zxtt23:21:09 08/05/13
