TwinTurbo.NET: Nissan 300ZX forum - High build surfacing primer, long sanding block, repeat.....
Subject High build surfacing primer, long sanding block, repeat.....
Posted by 280ZuL8R on July 11, 2013 at 8:31 AM
  This message has been viewed 148 times.
In Reply To Bigger posted by Jiro on July 11, 2013 at 05:18 AM
Message Fillers can be used for dings and chips but you never get good lasting results. The common scenario I see is the door is fixed with filler, primed, painted. The finished product will look good at the moment, but six months to a year down the road after that door gets hot/cold/hot/cold repeatedly it becomes noticeable exactly where the filler repairs were done. If the dings aren't too severe, try a high build leveling/surfacing primer. It may take a few thin coats with sanding between but it will produce better, lasting, results. As mentioned on your previous posting, I'd be skeptical on the color matching of the freshly painted door to the 20yr old paint on the rest of the vehicle.
1980 Datsun 280zx
1991 Nissan 300zx TT
2006 Nissan 350z
