TwinTurbo.NET: Nissan 300ZX forum - base timing is what is moving. The ECU does not effect
ae300z
on March 01, 2013 at 6:02 PM
Just curious, are you checking your timing with a
posted by michaell32 (FL)
on March 01, 2013 at 05:35 PM
base timing
JWT 500 cam CAS spline problem?
ae300z
13:52:39 03/01/13
CAS is worn out - sometimes caused by cam alignment
14:02:22 03/01/13
I would have thought you would have told me the spline
ae300z
14:28:39 03/01/13
CAS looks fine. (n/m)
20:23:28 03/01/13
So I just want to clarify this, the cause of the problem
white22sky
14:53:26 03/01/13
Re: So I just want to clarify this, the cause of the problem
Mike TDK (NoVA)
15:20:38 03/01/13
Thank you sir (n/m)
white22sky
15:57:12 03/01/13
Good info! (n/m)
VERTTZ
15:59:01 03/01/13
I am just now reading JWT's spline replacement
ae300z
15:23:41 03/01/13
I've had this problem on my '93 NA
OverZealous (CT)
21:31:47 03/01/13
Unfortunately it seems the misalignment can be either
ZXoltan
17:19:41 03/01/13
No not at all
white22sky
21:21:02 03/01/13
Doesnt look that worn.
Woody75 (Denver)
15:06:02 03/01/13
ouch, that looks nasty. (n/m)
ae300z
15:18:36 03/01/13
Amateur.
Stadsport (Nick@CZP)
13:16:30 03/02/13
You sir.. have no teeth or nothing there.. (n/m)
My300zx
16:33:11 03/02/13
When did you buy your jwt 500 cams?
VERTTZ
15:09:31 03/01/13
Bought them from IPP January 2010. Have you heard
ae300z
15:16:24 03/01/13
Yes there are issues known by a few and the timing of your
Only1Z
12:32:52 03/02/13
Can you elaborate further on the known issues? I have
ae300z
10:19:48 03/03/13
Well...
Only1Z
12:27:07 03/03/13
My issue is centered around the cam and CAS spline wear.
ae300z
14:59:26 03/03/13
I think you're confusing 2 different issues...
19:57:32 03/04/13
Yes which is why I said this might not be related at all to
Only1Z
00:23:18 03/05/13
michaell32 (FL)
17:35:54 03/01/13
base timing is what is moving. The ECU does not effect -
ae300z
18:02:59 03/01/13
TPS can also affect timing. Did you press the pin yourself?
RevTech
21:31:40 03/01/13
The base timing that is set with the CAS is my problem.
ae300z
09:54:06 03/02/13
Whats TIR? Did the TPS voltage move also?
RevTech
18:59:47 03/02/13
TIR is .016, TPS is good, set timing off #1 cylinder. (n/m)
ae300z
23:35:33 03/02/13
Unfortunately there are bad batches of 500 cams out there.
Only1Z
12:28:31 03/02/13
Thank you! Very true. My Sport 700 Comp. Flange Leaked!
ZinnZ32
17:22:23 03/02/13
Your turbo flange issue has nothing to do w. the topic at
19:52:33 03/04/13
Do you have any documention or examples to back this up? (n/m)
19:59:09 03/04/13
Someone I know who directly spoke to a more than
Only1Z
00:05:15 03/05/13
We used to play this game as kids called telephone...
13:42:17 03/05/13
All I've said is that a popular member here has said to
Only1Z
21:28:03 03/05/13
